Coda Feature Request: Add Tabbed Layouts to Row Detail Views
row detail views desperately need a tab feature for switching between layouts.
something like the current implementation for tabbed views would be great:
…but, you know, without the nested table inside of a canvas and whatnot.
yes, i know i can use OpenRow() buttons to make them, and have done so:
however it has big disadvantages:
  • it requires lots of formulas for the buttons and their actions
  • it’s forgotten each time the row is opened normally (Expand Row, clicking the card, etc.)
    • you can add a button with a ModifyRow() action that saves the current tab to a column, BUT that:
      • requires two extra columns — one for the button itself, and one for saving the current tab
      • overwrites it for all users
      • requires button() which is both harder to code and incredibly fragile
      • is too easily bypassed by opening the row normally
      • requires complicated formulas for the button to both write and read the current setting
    • you can have ModifyRow() write to a personal control instead, BUT that
      • STILL requires complicated button formulas
      • requires a separate control for each table or set of views
  • each tab requires a separate button, which takes up a lot of space
    • you can use button() to merge them into a single column, BUT that’s
      • way harder to configure than a normal button
      • requires button() for each tab (again, harder to code, incredibly fragile)
  • needs to be set up repeatedly for each table
  • OpenRow() doesn’t let you select a layout directly — instead, you have to pick a VIEW with that layout assigned to it. why???
  • OpenRow() overwrites the user’s viewMode setting (Fullscreen/Right/Center/etc.), even if left blank! why doesn’t it just fallback to the user setting???
i’m also aware you can embed a linked relation with a Detail View to switch between canvasses with embedded layouts:
but this:
  • requires a whole separate table just for the layouts
  • requires “template rows” with their own pre-designed canvases that get duplicated for each new row
  • requires a button to duplicate and modify those template rows
  • requires doing so for each new row in your main table
  • if you change one canvas, you now have to retroactively change every other version of that canvas to match (or create a button to regenerate template rows for every dang table)
  • it’s literally a detail view inside a canvas inside a detail view inside a detail view, which is crazy work
    • look at how tiny that embedded detail view is. the width is terribly constrained by all the padding from the nested table views.
so yeah, please introduce this feature natively, p l e a s e
This is a very well thought-out and detailed feature request.
Well done.
I vote for this!
Except I cant - because I have used up all my votes and cannot seem to get any more ?? !!
@Ruggy-Joesten, any chance of resetting our voting limits so we can VOTE on things?
Max
Letting the cat out of the bag a little early, but be ready for a nice update here with the forum refresh
Hello @Ruggy-Joesten
Regarding the forum UI refresh: is it planned or possible to turn the “Suggestions” category into a more Canny-like interface, where each suggestion would be clearly tagged by Coda as “Nope,” “Under review,” “Planned,” “In progress,” or “Done”?
I genuinely believe this would improve transparency and communication with the community. As it stands, most topics in this category seem to lead nowhere. I mostly see community champions stepping in with great answers and thoughtful workarounds, but very little input from Codans.
As a Coda lover (who now needs concrete releases more than announcements to rebuild confidence), this kind of change would feel like a clear and welcome cultural shift :+1:
sorry, could you clarify, is this update related to votes, or is it related to my feature request?
Apologies for the delayed response!
I don’t believe this can be built natively on the Discourse platform, but I’m planning to put together a doc to consolidate all the feature requests we’ve received, including the great suggestions that came in before I joined, so nothing gets lost. From there, my hope is to find ways to keep the community looped in as these ideas move through the roadmap process.
Votes! We hope to never again be burdened by the oppressive systems holding us back from freely engaging on the forum :flexed_biceps: :ballot_box:
oh ok! umm, would it be possible to get some clarity on the team’s position for the topic mentioned in the original post?
I’m circling back now and hope to have something for you today, @Swan_Song1
