Please!
Coming out of Notion, this is a huge missing point
I get Crossdocs and tables. But currently there is no way to move Pages and subpages other than manually and that is really time-consuming.
This also could improve flow and organization as in this stage for me I am constantly changing how I am structuring my content inside Coda.
So far, Docs feel kinda monolithic without this.
Is there any plan on pushing this forward?
I imagine that it can very quickly become very complicated to move even a single page, and even worse for a group of pages.
For every object on a set of pages, the links and references between those pages needs to either be maintained as to stay relative each other in the new set. Or they need to be changed, so that they keep referring to the original document. Or worse, you might want some to refer to the new doc, others to refer to the old doc.
If the object is a table, then assumptions need to be made for each and every table on whether to copy the contents of the table, or just the table structure. If there are formulas in the table, then as above, it needs to be determined how to copy those formulas.
Personally I work with a single doc as far as possible. And if there is a possibility that I (or somebody I share the doc with) will want to copy sections of the Doc, I keep everything on the same page. When the copying is done, it is then easy to organise the information into page and subpage structures.
R
p
Hello! This is now enabled via the feature update in this post: Launched: Copy a page to a another doc
Please, can we get the option to move a page to a different document, not just copy it? Of course, I can copy and then delete the original, but this is extra work and risks deleting the wrong original.
Thank you!!
Agree with this. Copy isn’t what I need.
Hello! Here in 2026.
Is this a feature that will be considered?? I agree with the previous commenters that copy and delete are extra (unnecessary) work and create room for errors.
Yes, you can effectively move pages (including subpages) between Coda docs, but it works as a copy rather than a true move.
In the Coda UI you can do the following:
Hover over the page in the left sidebar
Click the three-dot menu (…) next to the page
Select Add to doc → Copy to doc
Choose the destination document (and optionally include subpages)
This will create a copy of the page in the other doc. If your goal is to move the page, you can simply delete the original page afterward.
A couple of things to keep in mind:
Tables are copied as new tables in the destination doc
Cross-doc references may need to be updated
Permissions will follow the destination doc’s sharing settings
