Coda for Node/JavaScript
I just released CodaJS, a Node API for interacting with your docs.
I’m going to be using it in serverless and Gatsby projects to use Coda as a backend of sorts!
Let me know your thoughts!
This is awesome - thanks for sharing! I want to do something similar and use Coda as my backend for a Vue app. It seems like a great solution for quickly prototyping an fully functional app; maybe the best I’ve come across. I’ve used Coda with great success for in-house BI tools, but not anything public-facing yet. What’s your experience been like so far?
Thanks for Sharing Parker , I will use it during August , are your library using all the Coda APIs , or just them related to tables and records ? which is -in fact- also very useful -
Regards!
Thanks for sharing @Parker_McMullin
