Minor but important observation with packs
I have a pack where I have defined a parameter as “DOIs”
For some reason Coda assumes that is a typo and corrects it to “DO is”
The way I entered it in quotes is the way it really should appear.
Yeah it’s a little annoying at times, but I don’t know what a good general solution is, they have it documented here: Add sync tables - Coda Pack SDK
In some areas of the UI, such as the settings pane, the name will be rewritten to add spaces (“BugReports” => “Bug Reports”) for readability.
I prefer snake_case, which would result in less weird words when you convert the underscore to spaces, but that might be a bit late to change now haha. They probably had a good reason for chosing upper CamelCase though
For Pack columns you can override this “normalization” using the displayName field, but we don’t currently have anything like that for parameters, unfortunately.
