Coda Local-First, Agentic-First. Here's How
I told you this was coming.
Back in 2024, I wrote an article about the eventual demise of Coda. I bring it up now not because they’re going out of business, or sunsetting the platform—don’t panic—all software eventually hits a wall of entropy. It becomes bloated, irrelevant, or just too slow to keep up with the speed of thought. I warned that unless we built our own exit ramps and backstops, we’d be at the mercy of their roadmap rather than our own.
I’m still partly right, partly premature about that article. While generative AI as prominent when I wrote it, what wasn’t so certain was the renaissance of the CLI and locally running applications such as Claude Code, Google Antigravity, Geni CLI, and even Superhuman Go. These are all binaries that run in your local environment, and they have much more power when coupled with generative AI than any cloud-based conversational AI tool.
The window of competent AI bound to specific products appears to be closing, but not the way you might think. It’s time to build the ramp, but not necessarily the “exit” ramp. I see it as more of an onramp from a highway to an autobahn.
Enter Chroma, my latest experimental framework that draws upon Coda MCP and agentic platforms to fortify a local-first philosophy. It’s an agent-native backstop designed to both defend and accentuate your Coda investment by doing the one thing the cloud cannot do: move fast and integrate locally.
The ‘Claude Cowork’ Validation
If you think this is just me shouting at clouds, look at Francesco D’Alessio. The guy practically built his career on Notion, yet here he is replacing Notion with Claude Cowork. Honestly, I would ditch Notion for a lot less. :wink: But, ten million paying Notion customers can’t all be wrong at the same time. I’m skeptical of Francesco’s claims, but I’m also not under any illusion - I am following in his footsteps to a point.
This video is relevant because it validates the “local-first agentic” approach by showing how a leading productivity expert is replacing cloud-based tools like Notion with local agentic workflows (Claude Cowork), mirroring the Chroma strategy.
This image was generated by Antigravity by simply asking it to visualize my Chroma workspace.
Why? Because static pages are dead. He’s moving to a model where agents don’t just read your wiki; they work inside it. He’s using agents to plan, script, and track his entire channel by giving them direct access to his local file system. Chroma is that exact same architectural shift, but applied to your Coda ecosystem. It is the “Cowork” layer for your enterprise documents and data.
The Latency Lie: MCP is Still Remote
We’ve convinced ourselves that “real-time” collaboration is worth the cost of latency. In many cases, it isn’t. When I’m working, I don’t need a spinning circle; I need my data now. I need to sustain a pace that yields high output with deep context and zero switching costs.
Coda’s new Model Context Protocol (MCP) is a brilliant step forward, but let’s be honest about the physics. It’s still a remote pipe.
Here is the brutal math of the cloud versus the metal:
That isn’t a “performance improvement.” That is a different species of software. Chroma achieves this by creating a “Shadow Context”—a local mirror of your Coda workspace metadata that lives on your disk, not in a server farm in Oregon.
The Shadow Protocol: Privacy as a Feature
Chroma isn’t a backup; it’s a high-speed discovery engine for your personal knowledge management (PKM). It uses what I call the Shadow Protocol to bridge the gap between cloud collaboration and local sovereignty.
  1. Map: It replicates your Coda folder hierarchy locally.
  2. Index: It harvests metadata—Titles, Page IDs, Synopses—into Markdown.
  3. Link: Every local entry has a direct [Open in Coda] deep link back to the cloud “Truth”.
  4. Private Annotation (The “Clean Room”): This is the killer feature. Because Chroma is local text, I can have my agents (or myself) write commentary, notes, and strategic observations about my Coda documents without ever submitting them to the cloud.
  • I can run a sentiment analysis on a project plan.
  • I can draft “impertinent” critiques of a roadmap.
  • I can store private keys or sensitive context next to the public doc link.
  • None of this syncs back to Coda (unless I tell agents to do this). It is my private, local overlay on top of the shared corporate reality.
This means I can search my entire brain—years of docs, meetings, and ideas—in milliseconds. And because the sensitive project metadata remains on-disk, I reduce my exposure to cloud-only processing.
Why Agents Love the Taste of Chroma
I previously wrote that my “productivity sandwich” relies on ambient context. But agents like Claude Code or standard LLMs choke on the latency of cloud APIs. They can’t “think” if they have to wait two seconds for every memory retrieval. In complex workflows, the real-world state can change while the agent is waiting.
Chroma is optimized to allow agents to:
  • Visualize the Landscape: Agents can see the “knowledge topography” of my workspace—folders, documents, and schema—without hitting a single API rate limit.
  • Hybrid Workflow: My agents use Chroma to find where things are (discovery) and then use the Coda MCP to execute the read/write actions as needed.
The Visual Topography of Your Brain
When you flatten your data into a list of URLs, you lose the map. Chroma restores it.
As you can see in the topography example above, Chroma transforms flat lists into a visible map of your brain. I can instantly see which documents—like “Agentic Coda”—are heavy with content and which are just placeholders. It allows me to spot certain documents or “Ontological Skill Builders” at a glance.
Crazy Helpful Use Cases
  1. Personal Strategy Critic & Red Team Agent
    Point an agent at a folder of strategic plans → it cross-references related docs in milliseconds, drafts comments based on hidden assumptions or misaligned incentives, and stores them locally next to [Open in Coda] links. You review privately, then selectively push polished versions via MCP. This turns Chroma into a personal “red team in a box” for high-stakes thinking, far faster and more confidential than cloud-bound agents.
  2. Ambient Knowledge Landscape Explorer & Auto-Organizer
    An agent runs ambient/low-attention scans (e.g., daily or on file change) and annotates locally with emergent structure—like tagging implicit themes across projects, flagging outdated docs via date heuristics, or proposing new folder ontologies. When you need action (e.g., “reorganize these 12 scattered PRDs”), it discovers via Chroma and then executes moves/edits via MCP. This creates a self-improving, agent-maintained second brain overlay that’s orders of magnitude faster than querying Coda directly, perfect for heavy PKM users who feel Coda’s native view is too “flat/boring”.
  3. Hybrid Research + Synthesis Agent for Deep Work Sessions
    An agent designed for long-form thinking/writing (e.g., reports, proposals, or channel scripting like Francesco’s use case). It starts with local Chroma for instant broad discovery: “find everything related to ‘agentic workflows’ across my last 3 years of docs”. It pulls metadata/synopses in milliseconds, ranks by relevance/topography density, and builds a private context cache with your annotations. Then, for precision, it selectively uses Coda MCP to fetch only the full current content for the most relevant items (avoiding latency/token waste). The agent synthesizes, drafts, and iterates—all locally—while you stay in flow with zero spinning. Bonus: It can run sentiment/trend analysis on historical project evolutions privately. This mirrors the Claude Cowork local-first agentic shift but anchors it specifically to your enterprise Coda data, giving deep, fast context without the cloud round-trips that kill momentum in complex multi-doc workflows.
These use cases play directly to Chroma’s local speed/privacy edge, agent optimization, and hybrid read/write model—turning what could be a simple backup/mirror into a high-leverage cognitive accelerator.
Conclusion
Chroma isn’t just a safety net for Coda’s potential demise; it is a performance upgrade for your cognitive stack. I’ve always felt less than impressed by Coda’s interpretation of my workspaces. It’s flat, boring, and not very helpful.
Chroma ironically uses Coda’s new features—the Model Context Protocol (MCP)—to pave the way for a local-first future while embracing agentic capabilities. Chroma defends your Coda investment by making Coda the backend storage for a much faster, smarter, local frontend.
Stop waiting for the cloud. The future is on your hard drive.
ps, Anyone with Coda MCP access can build a personal Chroma today. Start by asking any competent local agentic platform to build it.
Note: I’ll gladly share Chroma with anyone with Coda MCP (beta) access. Drop me a note in the comments.
One of the cool things about agentic platforms is that they remember everything. Even for the laziest of tasks, I can simply ask my Chroma agent to build the blueprint for creating a Chroma solution in Claude Cowork. It’s likely that if you give these instructions to Claude, armed with Coda MCP, it will implement Chroma for you.
:building_construction: Blueprint: Building Your Own Chroma
A Local-First, Agentic-First Knowledge Index for Claude Cowork
This blueprint provides the exact steps to build Chroma, an AI-native metadata intelligence layer that bridges cloud workspaces (like Coda, Notion, or Google Docs) with your local agentic environment.
:clipboard: Phase 1: The Architectural Design
The “Shadow Proxy” Concept
Traditional KM systems force a choice: Cloud (Collaborative but slow Search/API) or Local (Fast Search but disconnected).
Chroma chooses a third way: Metadata Proxies.
  • Authoritative Source: Your cloud docs (Coda).
  • Shadow Index: Local Markdown files containing only metadata, structure, and synopses.
  • Workflow: Agents “Grep” the local shadows first to find context, then call the Cloud API only for deep retrieval.
:hammer_and_wrench: Phase 2: Standards & Schema
1. Mandatory Shadow Standards
Every shadow file must follow these rules for agentic reliability:
  • YAML Frontmatter: For machine-parsing doc IDs and sync tokens.
  • Hierarchical Titles: Preserve the folder structure of your cloud workspace.
  • Clickable Links: Every page MUST have a direct URL to the cloud source.
  • Synopses: Every document and page requires a 1-2 sentence description.
2. File Naming Convention
  • Format: Camel Case with Spaces.md (e.g., Strategic Roadmap 2026.md).
  • Pathing: /coda-docs/[Workspace Folder]/[Document Name].md.
:gear: Phase 3: Implementation Steps
Step 1: Secure the Foundation
Create your local vault structure.
mkdir -p chroma/coda-docs/.chroma-config
touch chroma/coda-docs/Dashboard.md
Step 2: Define your Scope (config.json)
Configure which folders or documents to index.
"workspace": "Product Universe",
"folders": ["My docs", "Foonman", "Ralph"],
"outputPath": "coda-docs/",
"maxDocsPerFolder": 1000
Step 3: Build the /chroma-sync Engine
Develop an agentic workflow that follows the Scan-Harvest-Shadow protocol:
  1. Scan: Use MCP (e.g., Coda Search) to discover all documents in your target folders.
  2. Harvest: For each document, fetch its structure:
  • Document Title & Synopsis.
  • Full list of Page Titles & unique Page IDs.
  • Last Updated timestamps.
  1. Shadow: Write/Overwrite the local Markdown file.
  • Generate YAML frontmatter.
  • Build a “Table of Contents” using clickable markdown links: [Page Title](https://cloud.io/d/DocID/PageID).
  • Inject synopses for every node.
Step 4: Initialize the Dashboard
Maintain a central Dashboard.md that lists all synced documents with their page counts and metadata highlights. This is your “Ground Control” for manual navigation.
Step 5: Enshrine the “Cartographer’s Oath”
Add a core behavioral rule to your agent’s system prompt:
Law V: NEVER read cloud page content without checking local Shadows first.
:rocket: Phase 4: Advanced Capabilities
:high_voltage: Sub-Second Topography
Because you are searching local Markdown, a grep across hundreds of document structures takes ~50ms, compared to 2-5 seconds for a Cloud API search.
:brain: Semantic Enrichment
Once you have local shadows, you can:
  • Auto-Generate synopses using your LLM to ensure they are high-quality.
  • Visualize Relationships: Use Obsidian’s Canvas or Graph View to see how documents overlap.
  • Agent Discovery: Agents can “explore” your knowledge base without hitting API rate limits.
:bullseye: Final Checklist
  • Local folder structure mirrors Cloud folders.
  • YAML contains docId and source URL.
  • EVERY page is clickable.
  • No full content is duplicated (Metadata Only).
  • Dashboard is updated after every sync.
Created for the 832Labs mcpOS Protocol
