Coda page flickers wildly at scroll to bottom
Hi Coda Community,
I’ve been experiencing a strange issue while using Coda in Safari. Whenever I scroll to the bottom of a Coda page, the entire screen **flickers wildly, making it difficult to navigate or interact with the content.unless you scroll back up
This issue seems to occur specifically in Safari Version 18.3 on macOS
, and I haven’t noticed the same behavior in Chrome or other browsers. I’ve tried clearing the cache and disabling extensions, but the flickering persists.
Has anyone else encountered this issue? If so, are there any known workarounds or fixes?
Thanks in advance for any insights! I did search first :slight_smile:
I have encountered what I think is the same thing. On a Mac I’ve used the shortcut, command + down arrow or up arrow, in order to take you straight to the bottom or the top of the table. It has been working for me. Hope that helps!
