i use regex tools a lot in my work. coda has its own particular implementation of the regex engine. so i needed a TOOL to help me verify what my coda code was doing with particular regex expressions and settings.
so i made this ultra simple tool that shows how the RegexMatch(), RegexExtract() and RegexReplace() formula functions work with my strings.
sharing it here as i imagine it is useful for other makers as well
max
Would love to see it! But sharing permissions aren’t set correctly. Can you shift it so we can view?
I hope to use Regex more in the future so this will be really helpful. I saved your post so that I can go back and check it out. Thank you so much!
This is great! Thanks for sharing!
Wanted to share a quick insight on the RegexReplace function, especially when dealing with backslashes in inline strings in formulas.
Issue: Using RegexReplace("\\","\\\\","\\") yields a double backslash (\\) instead of the perhaps expected single backslash.
Explanation: This happens because in Coda.io, “\\” is indeed read as “\\”, but a single “\” cannot be directly entered as it escapes the closing quotation mark. So, the string needs to be entered with double backslashes to be parsed.
Workarounds: A simple fix is using Character(92) for a backslash, or retrieving it from a table field.
Conclusion: Hope this helps those dealing with backslashes in RegexReplace. If you’ve found other methods or have questions, feel free to share!
I have been using Grok AI to help me write Regex formulas… it is WICKED good!
