Hi guys,
I have started working on python wrapper to use with Coda API. Please take a look here:
or install with pip install codaio
You can already use it for convenient reading of tables, more details in the README
It would be great if somebody was feeling like contributing an issue or PR. Thanks!
The library now includes all methods of raw API under the Coda class to conveniently access the API via python. For object oriented access I’m working on Document, Table, Row, Column and Cell classes.
Documentation: https://codaio.readthedocs.io/en/latest/index.html
Hi,
I would be keen to have a look at this, is there any way to get it running with python 3.6?
Cheers
Thanks for your efforts. Python is my preferred option for scripting, and your wrapper seems to be very promising
Hi, I don’t think there will any problem with 3.6, I just haven’t tested with it.
Try it out and let me know if you encounter any difficulties.
Hey am working with this now, its running great so far. Creating new docs, changing rows, retrieving data is all working great.
There is one function that my tiny brain can’t figure out though and thats the upsert rows.
Do you have a script example of using this, I have been trying your quickstart example
table = doc.get_table('TABLE_ID')
name_cell_a = Cell(column='COLUMN_ID', value_storage='new_name')
value_cell_a = Cell(column='COLUMN_ID', value_storage='new_value')
name_cell_b = Cell(column='COLUMN_ID', value_storage='new_name')
value_cell_b = Cell(column='COLUMN_ID', value_storage='new_value')
table.upsert_rows([[name_cell_a, value_cell_a], [name_cell_b, value_cell_b]])
I keep coming up with same error
Traceback (most recent call last):
File "main.py", line 16, in <module>
File "/lib/python3.7/site-packages/codaio/coda.py", line 884, in upsert_row
for cell in cells
File "/lib/python3.7/site-packages/codaio/coda.py", line 884, in <listcomp>
for cell in cells
AttributeError: 'str' object has no attribute 'id'
Do you have a another example of the upsert function working. I know this is going to be a facepalm situation for me but my brain is stuck.
Cheers.
Sure thing, will update the example.
Meanwhile can you send me your code, I’ll try to help. You can use a service like https://del.dog to send a snippet.
Version 0.4.7 added to_dict() methods for use with pandas:
df = pd.DataFrame(table.to_dict())
Hitch
September 29, 2019, 8:13am
9
Hi @Mikhail_Beliansky . Thanks for all your efforts.
I have opened an issue on github because I have been obtaining the same error message all the time
opened 06:55PM - 29 Feb 20 UTC
Hi, Mijail
Before all, thanks for all your efforts!
Now, I have tried to test your examples. I installed your library with pip,...
Thanks in advance!
Hey guys
I’m finding updating rows really slow.
I run the following:
from codaio import Coda, Document, Cell
coda = Coda('xxxx')
doc = Document('BPaCQ9TRbH', coda=coda)
table = doc.get_table('grid-aS3YxcCqqY')
row = table['i-IQNiTjKFCt']
print('Current Row Value')
print(row['c-frM4lIItoG'])
row['c-frM4lIItoG'] = 'Change Row 2'
print('After Update Line')
and get the following result, suggesting the change hasn’t happened
Current Row Value
Cell(column=Column 2, row=Martyn1, value=Change Row 1)
After Update Line
But after 2-3 minutes to change is reflected on the coda document.
This delay is causing issues with my script (i’m trying the reference the updated value soon after it’s updated).
Is there delay due to my code, or due to the API/Coda back end?
Thanks
