Color backgrounds for blocks?
Notion allows me to add a color to the blocks. Can Coda do the same?
To the blocks - can you be more clear?
I’m thinking you’re referencing something in coda using Notion terminology so you’re meaning isn’t totally translated.
In Notion, I can create a toggle headline and add text under it. I can change the color background of these text blocks.
I am wondering if there is a way to change the color background in blocks within Coda.
No way to color blocks of text but you can do this with callouts. In Coda callouts aren’t just paragraphs but can contain headers, lists, buttons etc, collapsible too:
(p.s. apparently Notion also lets you drag more stuff into callouts; it’s not immediately clear but there’s that tricky way)
