Columns with Wrap Text don't fully display on Mobile
I have a Text column with Wrap Text set. The value of the cell is “Can you please provide me with one more tool?”. There are more columns in this table (8 to be exact) and the table is using the default layout.
When I view this table on mobile, the height of the row does not fully expand to show the whole value of the cell considering text wrapping. I do see the text wrapping, but just not the full value in the cell.
I’m expecting that the row height would expand to fit the text regardless because the Wrap Text is turned on.
Is this a bug?
Hi I have this same issue. If it is not too much trouble, could you let me know if you have heard anything about whether this is fixed? Thank you -G
I have not heard anything @adoc_mama . Thank you for confirming it is still an issue.
