Hi Kyton,
thank you for clarifying that beta features are workspace related and not account related.
Hi Kyton,
I am on the Team Plan, I have the “+” and yes, I can create a new table view. But I have tables with already set views and I am unable to bring those and display them as tabs.
@Stefan_Stoyanov I am trying your way, but it doesn’t seem to be working with cards option. But I think I can copy data into a normal table and then turn it to cards and then use the same layout.
I guess there is no easier option
We’re planning to enable this in the next few weeks! You’ll be able to view different tabs in separate browser tabs without them syncing, and I’ll update you once live.
Appreciate the feedback, and apologies for any confusion! This should now be resolved, but please let us know if you continue to encounter related issues.
Thanks for the detailed feedback! We made some updates before today’s launch that should address the filter ghost bug as well as how we handle the overflow tabs to enable you to see more tabs when there’s space for them. Let us know how the latest updates feel!
On programmatic labels and badges—that’s something we’re considering for post-launch improvements. Really helpful to know this would be valuable for your use case.
This should be enabled in the next few weeks! Will keep you updated ![]()
Great question! Given feedback from folks like yourself, @Remco_de_Louw, and others, we have updated the logic so when you create the first tab on a table it’s always duplicate of the existing view.
If I understand your question correctly, at the moment you’d need to create a new tabbed view and recreate an existing standalone views as a tab. We are looking into ways to make it easier to convert existing views into tabs!
We’ve updated the behavior to allow different tabbed views to be selected in different browser tabs. Check it out and let us know how you like it!
Thanks for the request! We’ve updated the behavior to allow different tabbed views to be selected in different browser tabs. Check it out and let us know how you like it!
Verified! Thx, this makes them way more workable!
Also an idea… if you ctrl-click them, it would be nice if they behave like a url that opens in a new tab.
Great outcome , thank you !
Exciting news – you can now drag and drop a view onto another view of the same table to convert to tabs! No more recreating from scratch needed. Read all about this change, other tabbed view improvements, and upcoming roundtables in @Ruggy-Joesten ‘s Friday Features post ![]()
