// Comments in formulas
Being able to // comment in formulas, like in normal code editors
Agreed that would be a nice feature. There are some workarounds, as mentioned in this thread:
Would really love support for // comments in code also. Similarly, if a Rule could have a description. This way complicated docs will be easier to understand long in the future by the original author or more importantly, other people.
Hi all, Coda has opened up a survey on feedback about commenting. If you’d like to participate, here’s the topic with the information:
As clarified in the comment section in the survey topic, unfortunatelly this feedback is focused on page commenting, which is a totally different thing from formula commenting.
what?
i thought this was for commenting FORMULAS
which is needed URGENTLY
i have no use for comments on pages
we already have a mechanism for that
max
I agree. I think the comment section is well developed and they shouldn’t be taking so much attention to that. They should definetly add formula commenting, which is a crucial thing for bigger workflows.
Looks like Coda has an experimental support for /* comment */.
interesting, how did you find out?
:kissing: That would be huge news for me.
Unfortunately can’t reproduce it on my end :frowning:
Capture d’écran 2022-12-15 à 11.51.52
Maybe a test not deployed everywhere ?
alas, the OP example did not just fail on the // as indicated by the red markers.
thats probably due to the way the parser works, it didnt understand the /*111111*/ token and it didnt understand the // token either, but it only reports one error, not all the errors in the expression.
so; neither the //xxx// nor the /*xxx*/ are understood as comments
max
:wave: Hi! I’m Arpan, a software engineer at Coda. I’m excited to share that you can now add comments to formulas! By enclosing parts of your formulas with /* and */, that portion will become a comment. To comment out an entire line, prefix the line with //.
Formula comments can help explain what’s going on in your most complicated formulas and can also be used to save prior versions of formulas you’d like to refer back to.
OMG FINALLLLLYYYY!!!
Hi Arpan,
thank you for such good news! It’s a pity to find it a bit hidden at the end of a thread — your post should totally be a new post in “News from Coda”, to make sure everyone in the community is aware of it!
Hi @Arpan_Laha, this easily deserves a News From Coda post! Super good.
