In the morning Buttons looked great! Now a LineBreak() is being inserted into the cell as the first column. Here is an example of the bug:
I have the same problem ![]()
Thank you for the bug report. This issue has been fixed and is available now. If you open a doc in a new tab, or refresh your existing tabs, you should pick up the change and the buttons should display as expected.
Hello @Matthew_Tebbs
Thanks for this correction :). I would like to know if there is a provision to be able to resize each element in a cell to be able to center it vertically?
As we can see here with dates or buttons, which makes the document less visually finished.
Sincerely,
Thierry
