Conditional logic in forms
Hi
My original thread on this is locked.
Is there any update on whether this feature will be implemented?
Thanks
Shaheed
Morning Shaheed!
Maybe this helps you in the meantime - it’s possible to implement some conditional logic with forumulas.
You can actually implement this functionality right now by adding a validation formula directly to the field. In Coda, you write a formula like: IF(condition, true, false)
This means that the field only accepts a value if the condition returns true. For example, you can check that if a status equals “Exit”, then the associated date field can’t be empty or not in the future - even if the date field isn’t marked as “necessary”.
