I am trying to create an All Tasks table to centralise all tasks across multiple projects. The details for the respective projects are across different pages and folders.
When I try to reference these folders they aren’t available as an option.
Is there a workaround to solve this?
Hi Andy,
Welcome back!
Pages:
I assume that you have different tables on different pages - off the cuff the suggestion from most Coda enthusiasts would be to have a single table, with different views on the pages.
Folders:
You cannot access folders or other documents in folders from a doc using the Coda Formula language. You would need to establish a link using one of the cross doc or one of the webhook packs.
Regards
Piet
thanks for your quick response Piet
