Contains(), ContainsAll(), ContainsAny()
Contains (value, search)
Checks if a list contains any value from a list
Contains("Dog", "Cat", "Mouse") ⟶ False
Contains("Dog", "Cat", "Mouse", "Dog") ⟶ True
List("Dog", "Giraffe").Contains("Cat", "Mouse", "Dog") ⟶ True
INPUTS
value – A value or list of values to search in
search… – A value or list of values to search for
OUTPUT
Outputs True if any value in search exists in value.
ContainsAll (value, search)
Checks if a list contains all values from a list
ContainsAll("Dog", "Cat", "Mouse") ⟶ False
ContainsAll(List("Cat", "Rabbit"), "Cat", "Mouse") ⟶ False
List("Cat", "Mouse", "Rabbit").ContainsAll(List("Cat", "Mouse")) ⟶ True
INPUTS
OUTPUT
Outputs True if all values in search exists in value.
ContainsOnly (value, search)
Checks if a list contains only values from a list
ContainsOnly("Dog", List("Dog", "Mouse")) ⟶ False
List("Dog", "Mouse", "Cat").ContainsOnly("Cat", "Mouse") ⟶ False
List("Dog", "Mouse").ContainsOnly("Mouse", "Dog") ⟶ True
ContainsOnly(List("Dog", "Dog"), "Dog") ⟶ True
INPUTS
OUTPUT
Outputs True if only values in search exist in value.
I have two sets, A and B, of the same type.
I have to find if A contains any element from the set B.
What would be the best way to do that without iterating over the sets?
The Set library has contains(object) and containsAll(collection) ,
but not containsAny(collection) .
Hi @Jhon_Albert,
Contains() is a “contains any” formula. So the following should work for you.
[List A].Contains([List B])
Give that a try and let us know if it doesn’t work.
It doesn’t work @Ben_Lee
Dear @Jhon_Albert,
It would be of great support if you could share a dummy doc showing what exactly doesn’t work or give you the expected outcome.
Thank you.
Like like I answered too quick, sorry about that. Give this a try.
[List A].Filter([List B].Contains(CurrentValue))
Something like that should work. We need to check each item in List A individually against List B. You’re going to have to iterate through at least one of the sets.
In this case, why Contains() returns all rows when you can see not all contains that value?
I realized this as part of FormulaMap filter criteria, which made 1 action instead the nr of rows, which makes me more doubtful about reliability…
Hi @Balint_Drahota
Try this. If you don’t use Count() as the Contains simply returns true or false the filter isn’t valid.
