Contains - Item x AND (item Y OR Item Z) in coda language
Hi!
I want to apply a filter to a table, but I’m missing the right formula. Can anyone help?
What I want:
I only want to see items of a table where itemX = checked. In addition, I only want to see items that contain Y OR Z. So basically, itemX= checked always has to be true and from that selection I want coda to only show me the rows that contain either Y or Z.
What’s the right filter formula for that?
Hi @Patricia_Hoffmann :blush: !
Maybe this could work :
thisRow.X AND thisRow.Items.Contains(Y,Z)
where :
  • The condition 1 is: thisRow.X
    • It returns true if the checkbox X is checked
and
  • The condition 2 is: thisRow.Items.Contains(Y,Z)
    • It returns true if the value in the field Items contains either Y or Z
And for the filter to returns one or more rows, both conditions needs to be true (as I used AND) :blush:
Here’s a sample to illustrate :blush: .
The filter formula has been applied on the [View of Table] so you’ll be able to see the differences between the unfiltered source table called Table (where the results of the filter are highlighted through conditional formatting) and the actual filtered view.
I hope this helps :innocent:
Thank you so much!! It helped a lot :slight_smile:
My pleasure @Patricia_Hoffmann :grin: !
And I’m very glad to know this helped you moving forward :grin: !
