Can anyone think of a way to copy the content of a code block with a button?
I have long code blocks that people need to copy
Thanks
Thanks
Hi Tim,
Welcome to Coda! You give very little detail around your requirement. But one way to do this would be to put your code blocks in a column in a table, and set up the relevant buttons in a table in another column. You can then “copy to clipboard”, or into another table, or do any formula manipulation needed.
Regards
Rambling Pete
