Is it possible somehow to allow users to copy text of a doc without allowing them to copy the whole doc?
I am sure there is a solution as it is a very simple and I believe natural feature to have, but I cannot find the way how to do it.
I read a topic about this saying that I should publish the doc in “Play mode” but that doesn’t work anymore neither.
Thanks in advance if you can share the solution!
I also needed this teacher from time to time.
It would have to be done via the API. I would recommend adding this prompt to Claude or ChatGPT:
Search for relevant Coda API and Coda Pack documentation.
Write the code for a Coda Pack that allows the user to, in a single button click, copy all of the text in their doc, formatted in CSV.
The pack should use the Coda API to fetch text from all Pages and Table Columns/Rows.
The pack should use Coda-managed authentication to let the user create a new API key.
Hi, sorry I’m a bit late to the party and I don’t have much time to elaborate but you should look at the “Copy to clipboard” button which is pretty useful.
