Creating a notification for a timer
I have a document that has a timer that is reset whenever a button is pressed for either 1 minute or 2 minutes, when the timer ends I want to be notified as part of a workout app where the in built timer is to time between sets.
I have a button that notifies me through coda and a timer that works but I want to be able to press that notification button via a formula when the timer ends which I cant seem to do. The automations function doesn’t work for this in any iteration I’ve tried.
Also is there any way to get the notification to make a sound either through coda or through some pack or extension?
Thank you!
HI Callum,
This doc shows how to use a button to trigger a soundwave.
I have started simplifying the doc, but not quite done yet.
R
P
I would absolutely love for this functionality, too! I have a coffee timer and it gets kind of annoying to keep looking up at the screen while also monitoring my pouring- a little “ding” would go a long way.
