Creating a SharePoint Pack
Hello!
I know there’s a couple different OneDrive packs. But how difficult would be to create a pack that connects to SharePoint? I basically need to save files to SharePoint document libraries instead of OneDrive folders.
@Scott_Weir1 and the folks at SimplaDocs recently created a Sharepoint Lists Pack, so you may want to see if that’s something they could do for you.
@Samuel_Langford - I had the same need; plus plus a few evolving use-cases…it took 2-3hrs of back and forth testing by the agent - I think i used Google Anthropic; but you can use any of the other models and just let it look at the coda pack sdk - (10 prompts; tries etc)
