Is it necessary to create a new table for each layout?
I assumed with Coda formulas, formula library, formula cheat sheet - Coda
** viewOrLayout**
You were able to create multiple layouts and reference them with a table.
- View being the extra tables
- Layout being the style of a table
instead it seems that you need an active layout ( which also means table) to reference the table view or the expanded layout.
AJM
2
you’re correct. I have no idea why coda named it ViewOrLayout, but it drives me insane.
@Ty_Xanders , it is like @AJM said, you cannot. I wrote a blog about it to explain this inconsistency that coda has to solve:
Let’s make it sing indeed, thank you for this.
I’m glad i’m not just going insane like @AJM ( there’s hope for you yet)
I’m using this button with formula trick to create an open row button that opens a different layout based on a column value:
https://connect.superhuman.com/t/different-layouts-for-row-detail-view-in-the-same-table-view/43794/4
Works great!
