Customized Sorting
I would like to create a customized sorting to sort according to the status of a todo list. When the status is Today, I would like to put these task in the beginning. Is it possible. Since if I sort according to the status, it always go with the alphabetic order.
This is what I used. Interested to learn if there’s a better way.
@Hao_Yan If you are open to using grouping in your table, you can re-order the tasks by status in any way:
Thank you. That is a good work around.
