Dates format on charts are not according to table
Hi,
Anyone knows a workaround?
I have a column as DATE, formatted for “DD/MM/YYYY”.
If I just change the display to bar chart, it uses “MM/DD/YYYY”. Am I missing anything?
Hello @Adriano_Carvalho,
I think this is something that needs to get fixed by the Coda team, but in the meantime you can get around it by creating a text column that you reformat the date into dd/mm/yyyy and then using that new column in your chart instead as shown below, thanks!
Awesome, thanks! So indeed it’s pending
Thanks a lot for the workaround.
