Default currency format
Following on from having default non-US date formats please can we also set a default currency format. I’m working on a few tables with currency and it also defaults to the all ighty ollar. Please can we set our own non-US currency as the default (along with dates)
and also the decimal separator. the rest of the world needs a comma non a period to separate the decimals.
I would also love this feature. It’s very frustrating to create a table that has 10 currency fields and change the currency symbol and decimals to all of them individually. I always use the same settings: €-symbol and 2 decimals. A simple Default currency symbol and decimals selection in profile would save a lot of frustrating repeated dropdown clicks. Another option would be to allow copying column format.
Also as a side note, there should be support for using the currency symbol on the right side of the amount as is the standard with a lot of currencies (eg. Euro).
Just noticed one shortcut for using Euro:
If I enter a sum with leading €-sign to an empty column, Coda autoformats the column to Euro currency and puts 2 decimals
Screenshot 2020-08-21 at 10.43.00 => Screenshot 2020-08-21 at 10.43.15
Easiest way is to enter €0 as value
Anyone interested in this, to vote this suggestion, please click the vote button on the top next to the topic
the topics date / currency format have been out here almost 3 years. why dont you have it implemented yet??? @Harry_Doan
Four years later, the topic hasn’t even been addressed?
Please coda, Why I can not format the Euro sign to be on the back of the number? This is so annoying, why does the Euro sign does not go to the back instead of the front? It’s almost impossible to convert it when I need to send it to my accouter in Excel. Here in Europe the sign goes in the back, so Excel can not recognize it as a number … If I need to do this manually, all the work that I did in CODA is a waste of time :(… Please someone can help me find a solution?
Unfortunately, I can’t use Coda until the option to set a default currency has been introduced. It takes far too long to change every column manually…
