Deleting Columns is too easy
I have done this multiple times, and it drives me crazy. I add a new column, and I click in the column heading, thinking I have switched to where I can edit the name. Apparently, I have not switched to edit mode because when I hit the backspace key to delete the default text instead it deletes the column and several others because I hit the backspace key several times. Thank goodness for the undo feature, because I have been able to bring the columns back. It should not be that easy to delete a column. Can you please make it so that hitting the backspace key while in a column heading doesn’t delete columns, or at least make you confirm that you do indeed want to delete the column?
Thanks
Backspace yes, but not the delete key. Please please please don’t introduce a confirmation step for column deletion, that would absolutely SUCK.
