Dependent choices
Hi!
I’ve been discussing the following problem with ChatGPT and Claude for a couple of weeks, but they haven’t been able to solve it. Instead, I’ve spent hours going in circles (but learning a litlle about Coda).
I want to create a table with two dropdowns. The first column—Letters—has two choices: A or B. The second column—Numbers—has these choices: 1 or 2 if you’ve chosen A under Letters and 3 or 4 if you’ve chosen B under Letters.
This is of course a a simplified version of something a bit more complex. Any help would be highly appreciated.
Please take a look at the example in this doc. Does this look like a solution to your problem?
hi @Tamerlan_PRO , can you adapt the share settings, we cannot view it.
merci, cheers, christiaan
Oh, sorry, here it is)
nicely solved with:
CurrentValue.in(thisRow.Letter.[Linked numbers])
filtering inside relations feels difficult for most users new to code since you have to put your brain on something true ‘inside the filter’, meaning you have to focus on the condition itself that defines what is true.
Excuse me, @Christiaan_Huizer , are you suggesting that there might be a simpler alternative, which honestly doesn’t come to mind for me? :sweat_smile: Or are you simply emphasizing that understanding the importance of the described concept is a key point when working with filtering in Coda?
@Tamerlan_PRO
This is simply a good solution, in terms of syntax I prefer Contains() , but that is only a perso pref and does not affect the outcome at all.
I made my comment for those new to coda and want to understand what happens under the hood, you did a great job :wink:
@Christiaan_Huizer Thanks for your message! I was curious about your perspective—maybe I’m so used to diving into Coda’s advanced features that I might be overlooking a simpler solution, so I thought I’d clarify. :nerd_face: I completely agree with your points, by the way. For someone who’s worked with Notion for a long time, where filtering within relations doesn’t exist, filtering in Coda feels like magic—it really makes life so much easier. :sparkles:
there is a native solution for this inside Coda using filters , i think it was added lately you can try it
