Directly apply filters to buttons
I often want to filter a list dynamically. Today i always have to jump into the filter section, change the filter for a table and have to do it again as soon as i finished work on that filtered view.
It would be great if i would have the same filter possibility like for a sheet, but could apply it easily to a button which allows me to turn the filter on or off.
Today it seems to be complicated to do this, with controls and formulas.
That means, something similiar to interactive filters, but with more possibilities.
You can use a /setcontrolvalue button to set the control to a specific value and then another button to /setcontrolvalue to blank or in other words “Clear” the filter.
