Disabling a button with (somewhat) tricky criteria
I want to disable a button in a table if two columns in that table (formatted as text) exactly match two other columns in a different table (row specific)
Hopefully that makes sense. Screenshots explain more.
CODA%20Disable%202
Hi @Scott_Weir,
Does this do what you want? I’ll admit that it was a bit hard to understand the structure of the tables you were describing.
==> Disable If: [Master Feedback].Filter(Student=Student AND Teacher=Teacher).Count()>0
Lloyd
Hi Lloyd, just wanted to say thank you for the formula :slight_smile: Such a simple one but I’ve been struggling all evening
