Discourse Hub App
If I try to load the community through the iOS Discourse Hub app I get an error
Is this an error with my account, an error with the server or not a provisioned feature?
Dear @Sean_Sloan,
I scrolled through the permission settings, but didn’t notice any limitations
https://blog.discourse.org/2018/06/understanding-discourse-trust-levels/
@Ben_Lee, are you aware of any limitations?
I’ll look into this to see what’s going on. I actually use Chrome for the community on mobile, but will check out the discourse app and see if our install is compatible.
Thanks @Ben_Lee,
I am also on chrome mobile, and tried the app on Android, no problem. The actual question was about the IOS.
Was wondering if there was any update/outcome on this?
Still no fix for this?
Hi,
having the same problem on the iOS app - it might not be the app as such, as I am having other communities in the app working.
Does this help?
Any progress on this?
How do you work out what your trust level is and what is the trust level required to be able to use the Discourse Hub App?
