I have a table in Coda with almost 500 rows. I just want to show the top 100 rows with the highest count. The column ‘Count’ is already sorted to decreasing value. How will I do that in Coda ? What filter formula should I use ? Thanks!
There may be an easier way that I’m not thinking of, but one way would be to use the Rank function in its own column to assign a rank to each row, then just filter on that rank column (i.e. only show rows with Rank <=100).
Thank you for the idea. It helped me.
thisRow.In(thisTable.Sort(false, thisTable.Count).Slice(1,100))
This helped me. thanks
