Doc Explorer pack issues?
Happy Sunday all,
Anyone else having issues with the Doc Explorer pack @Scott_Weir created? I keep getting the below error:
Thanks.
Hey @Karina_Mikhli ! It seems to be working for me on the AllColumnData Sync Table -
Thanks for letting me know. Not sure what’s going on with my doc :(.
i encountered this error with a very large doc with dozens of tables, some of which had hundreds of columns.
so i think the pack takes too long to gather all the meta data from such a complex doc, and it times-out.
if i remember correctly, there is a maximum run-time limit on packs.
so i had to run the pack on each table separately.
max
Hi Max,
Thanks for this. I’ll try to figure out how to run it by individual table then and see if that does the trick. Appreciate it.
