Does Coda support conditional questions in forms—showing Question 2 or Question 3 based on the answer to Question 1?
I’m trying to build a form in Coda with three questions, where Question 2 and Question 3 are conditionally shown based on the answer to Question 1 (e.g., if Q1 contains Intern, show Q2; if Q1 contains Employee, show Q3).
I’m using a form created from a table, but I don’t see any option to conditionally show/hide questions (like branching in Google Forms). Is this a current limitation of table-based forms, or is there a specific way to enable conditional logic?
Unfortunately, coda doesn’t support that kind of functionality yet. It’s a feature that’s been asked for a lot in the past though.
