Does not count occurrences in another table's relation column
Table 1 has a list of items in the first column.
Table 2 uses that list in a relation column, where I can select options.
When I try to count the occurrences in Table 2’s relation column from Table 1’s list of items, I get the total number of rows in the column or 0. This is the formula I’m using:
[Table 2].Filter([Table 2].[Relation-Col].contains(thisRow.Items)).Count()
Hi @Jana_Lumi and welcome to the Coda-Community,
can you please share your doc for better understanding?
Sincerely
Jannis
Hi Jannis,
Here is the link: https://coda.io/d/_d9TkZhx_sm4/Untitled-page_su844
Hi @Jana_Lumi,
please check if the following doc is your solution:
Sincerely
Jannis
I found a work around, but I think there is still a bug with the system. Because when I typed in the solution from scratch as a formula it did not work:
But when I used Linked Relation to do this:
I got the list of rows as expected.
Then tapped the formula button. All I needed to do after was add: .Count()
However, when I add .Count() I get an error message:
This was not a problem before.
You can see it here: https://coda.io/d/TroubleShooting_d9TkZhx_sm4/
You simply have to change the Column type from “relation” to “number” in order to solve this bug…
I hope that finally solves your issue.
Sincerely
Jannis
