Dragable Weekly View
Hello all, im working in a small project for my own setup… the idea is build dragable weekly calendar similar the one seen in other platforms.
what i have now is task list with weekly view but the main issue that im facing is in the weekly view i only see the days that has tasks which a bit bummer… so is there a possible way to fix that and still maintan drag and drop tasks between them? the main goal is to have list of all unassigned tasks and i drag and drop them and they get assigned to the date of this week.
is that possible??
also i wish i can change the viewing accordingly like showing only 3 days, 7 days or 14days for example this would be ideal
this is the coda link if you want to help :
If this is a weekly schedule, you should change your date field to a text or select field. The problem with a date field is that you won’t be able to make a nice weekly task view, because when you add new items your view will keep on expanding (to the right) with new dates, even though you show them by day-name, they are still dates.
My sample in your doc shows how it can be done (assuming I understand your goal). You can set some options in the group settings:
On a desktop you can move the card around by dragging and dropping, on mobile you have to open a card and change the date.
If you allow for all seven days, there is no easy way to not show Saturdays and Sundays in your card views.
I added some views to your document.
