Hi Everyone,
Because we can’t choose what Coda columns are editable and which are not, I decided to create automation to notify me via email when due date is changed.
But a question is, how do I include in a body of email - old due date, new due date, and user who made a change. Right now I only have task name where the due date changed.
Thanks a lot!
Hey @Vitaliy_Malanchuk! Usually when you want to include column contents in the body of a message, I recommend making a column that contains the body content you want and references those other columns. This makes it easier to grab that content column formulaically.
If you need more help, I think it’d help to see your doc setup. Could you share your doc here?
Thanks a lot for the tip, will try this method.
