Duplicate Buttons
Hello,
If I have several similar buttons, how can I just copy the first then modify the rest?
Hi, you can include buttons in the table, in the settings of table change off “Column header”, “add row”, and “view grid”. You should get a blank canvas with button
Then use a copy of that table, that method should work.
Thanks Evgeniy - I will try that workaround!
