Easier way to filter table
How can I set up check boxes to filter the table? This is what I want to achieve:
1. I have a table with all projects (each row is a project)
2. I click the checkbox which will show me just the active projects (active = the project has already started but didn’t end yet)
But what happens now:
I have managed to fix it by using a list instead of a checkbox filter… but that is less user friendly:
How can I achieve what I want using checkbox filters?
Thank you!
Dear @Kars_H, welcome to the community!
You might want to check out this contribution of @Federico_Stefanato
Checkboxes: Dependent canvas checkboxes and improved checkbox table column type options
Hi @Kars_H,
Welcome to the community!
This should just be a matter of creating the right filter formula for the table. In cases where you want to see the table by a certain aspect if true and want to see everything if false, there is a trick you can use to simply return true for everything for the false option.
For your table, a filter you could try is:
If([Choose Active] = true, Active? = true, true)
[Choose Active] would be the name of your canvas checkbox at the top. If that is checked, [Choose Active] = true , then show rows where Active? = true. Else if, [Choose Active] is not true then return all rows as true. The last true is really just saying return true for the filter so everything will show.
