Hello,
Is there any way to easily transfer table format + Conditional formatting + Filters/sort settings between several tables, for example in case of using cross-doc? Maybe there should be a feature to just copy some lines of code…
Dear @PM_RSG,
Welcome to the community
For the time being only a table connection with a lookup is able to use the formatting of its original table.
Under suggestions you will be able to share your ideas and in what context you think the suggestion is beneficial for a wider group of users.
The Codans are open to suggestions and have implemented many ideas
