Enabling checkboxes/dropdowns on shared links
Is it possible to make the checkboxes and dropdowns usable when sharing a link to a document with view permissions? I want to share a document to a client where they are supposed to be able to filter a table by using a set of checkboxes and dropdowns. I don’t want them to have to create a Coda account just to do that. I know I can make different views etc, but that’s not viable in my case.
Is it possible?
Hi Daniel,
The ability to use checkboxes and dropdowns for people without a Coda account is currently only possible if you Publish Your Doc to the World. I understand if publishing your doc isn’t something that works for your use case. I’ll be sure to add this as a feature request on your behalf though. Let us know if you have any additional questions.
Best,
James
