Pressing Shift+Enter creates a line break in a cell. However, when editing a bulleted or numbered list, Shift+Enter does not create a new item. It’s pretty frustrating and tricky to work around.
I’ve discovered that it is sometimes possible to work around this problem by expanding the cell to full screen. It only seems possible when using detail display though.
hi @Bjorn_Hansell ,
did you consider using this trick with Char(10)
Concatenate(thisRow.Firstname," ",thisRow.Lastname,
Character(10),thisRow.Address,
Character(10),Concatenate(thisRow.PC, " ",thisRow.City),
Character(10),thisRow.[Mobile number],
Character(10),thisRow.Email
It forces a line break in a cell
Cheers, Christiaan
You need to use Control + Enter to create more list (bulleted, numbered to do) items @Bjorn_Hansell.
ctrl+enter works. Thanks @Johg_Ananda!
