I’m referring to the formula of this Pack: Currency Converter Pack, extend Coda with Currency... | Coda by @Hector_Reyes (@Hector_Reyes1 ?)
I’ve been using it for a while and it mostly works great, but sometimes the formula outputs an error ("Failed to fetch data from Currency Converter”) even though the preview seems to work.
I’m not sure whether this is a pack issue of a Coda issue. Because if I create a new inline formula and paste in the exact same thing that outputs an error in the original instance, it works fine and gives me a number! So the pack is likely not at fault.
In the past the issue resolved itself after a while, but I’d like a more permanent fix ![]()
