Export formulas
Hi :coda: Community :wave:
Is there a way to export/visualize all the column formulas I made in a doc?
Best
Thomas
Dear @thomas_raizedai,
Unfortunately not, the only way is to do it manually :frowning_face:
I’m rather sure you are aware of the option to put them in a code block as below sample:
NetWorkingDays(thisRow.Start,thisRow.End)
You might consider to add this post to the suggestions :thinking:
