Feature Request: Allow users to customize @-mention search priorities
Problem
When using @-mentions in Superhuman Docs (formerly Coda), search results are presented in a predefined order, with people and pages frequently appearing before table rows.
For users who rely extensively on table-based references within their documents, this creates unnecessary friction and significantly reduces the efficiency of the writing experience.
Use case
I maintain a centralized glossary (ABC) in a dedicated table within my document. This table contains terminology and definitions used throughout our internal policies and procedures.
While writing these documents, I frequently insert @-mentions referencing specific glossary entries.
This functionality is particularly valuable because readers can hover over a referenced term to view its definition without leaving the document.
However, when I type something like @b, the search results initially show numerous colleagues and pages before eventually displaying relevant entries from my glossary.
Finding the correct reference can require extensive scrolling or typing additional characters, interrupting the writing process.
Suggested improvement
Allow users to customize the search behavior and priority of @-mentions.
Ideally, this would include:
Customizable result priorities: Allow users to determine whether people, pages, tables, or table rows should appear first.
Preferred tables: Allow users to designate specific tables as preferred sources for @-mentions.
Contextual search: Introduce an option to search directly within a specific table, for example by using a syntax such as
@ABC:term. -
Persistent preferences: Remember these preferences at the user or document level.
Why this matters
One of the key strengths of Superhuman Docs is the ability to combine structured data with traditional document editing.
Using table rows as inline references creates powerful opportunities for interactive documentation, particularly for policy manuals, compliance frameworks, knowledge bases, and internal procedures.
However, the current search behavior makes this functionality unnecessarily cumbersome.
Workarounds such as manually copying row links or navigating back and forth between pages defeat the purpose of having an efficient inline referencing system.
Expected benefit
Giving users control over @-mention search priorities would significantly improve the writing experience, especially for organizations using Superhuman Docs as a centralized knowledge management and documentation platform.
Even a relatively simple option to prioritize one or more specific tables would already make a substantial difference.
