Filter a lookup column based on multiple entries in filter column
Hi All,
I am in need of the collective wisdom - I can set a filter on a lookup column that will filter the potential values based on a single entry in another column. E.g. to discriminate between hot and cold beverages. (Filter column beverage type = Hot will only allow drinks with beverage type hot. Hot coffee, and not Ice Coffee. )
Can it be setup where the filter column has multiple entries. E.g. a tag column where I want in the lookup column to show me all articles related to tables and canvas columns, but exclude the ones on buttons.
Like in the example below:
Regards
Rambling Pete
Hi @Piet_Strydom
I’m interested in this subject so I humbly had a look.
I copied your doc and took this example, adding on purpose dummy tags
I tried in a new table to get all event with tag Table but not AddRow()
And the proposal is well 02 and 04
In this case, I assume we can find a given tag only once in your table, the find function should check all the tags as multiple entries
And I dont see why I couldnt make any “AND” condition as I want, as we would do directly in the main table
Did I well understand … ?
Cheers
Quentin
Hi Quentin
Thanks for the quick response.
I am traveling at the moment, but I’ll have a look when I can get to a computer again.
Thanks a lot
Piet
