Filter button not updating?
Hello! I’m trying to set up a “project page” template. It has two tables, referencing a master Task Database and a master Meetings Database. As I create a new project, I’d like to click on the enabled filter button for the “project” column and select the project which this page relates to.
However, when clicking the button only a few of the available projects show up:
There should be quite a few more, as shown when clicking on the project column:
(can’t upload more than one image)
And bonus question, I have now set up a few buttons to add:
  • A new contact person
  • A new company (where person works)
  • A new project (for that company)
  • A new meeting (for that project)
  • A new task (for that project)
Can I make a form or something and not have to click through this setup?
Hey there!
Here’s what’s going on. You currently have two tables:
  1. Projects
  2. Project Tasks
When you click into the lookup column to select a project for the row it brings up every Project in the projects as an available selection
When you click into the filter drop-down to filter your Tasks table it is only showing the unique values/projects currently in the tasks table (hence why you see less options).
As soon as there is at least 1 task associated with each project then your filter bar will show the same selection as the lookup column
