I think I’m grasping the question here. My suggestion is to use a View of this table that only shows the groups you want to display in your card view. Then you can Show All Groups for that view where the ones you don’t want are already filtered out.
Hi @Ben_Lee does this actually work? I created a view that filters to a subset of the groups. However, when I use the “Group options” > “Show empty groups,” I actually see all empty groups EVEN if they have been filtered out of the view.
I just tried this myself and found that you can’t filter out blank groups even if you filter the view. I asked out engineers as well and this is working as intended. But … we can definitely see the use-case and that this would be beneficial, so we’re adding it as a feature request.
For now, if you’re using a Select List or a Text column type, you can “pin” the groups that you want to stay. It depends on your setup as to whether this will help as a workaround though. If your groups change a lot or if you have lots of groups to go through, this could be too cumbersome.
Indirect work has been getting done on groups that can lead to this being possible, but direct work on this hasn’t been done yet.
Groups aren’t all that easy to make happen and they also aren’t easy to make performant so our current work has been optimizing those types of aspects that will hopefully pave the way for other improvements like this in the future.
Sorry it’s not better news at the moment, we just have some foundational work to do first. It’s not a forgotten request though.
