How to do that :
have a look here @Isebar_DE ![]()
Cheers, Christiaan
Hi
you can do it with this formula for example:
thisTable.filter(currentValue.Name == Name).find(thisRow).count() > 1
Hi Christian.
Thx for the answer but this is way to complicated for me. ![]()
Still very much a beginner with coda.
hi @Isebar_DE , I am sorry to hear that, the blog intents to show a fundamental principle you can apply in various contexts.
it is the same logic as developed by @Math_24 , but he writes a kind of Javascript inside Coda (using == for example, which may be confusing when you are not familiar with JS).
He will respond to you and I guess he suggest to replace currentvalue.name with thisRow
Cheers, Christiaan
hi @Isebar_DE ,
in two steps:
thisTable.Filter(Name.Contains(thisRow.Name)).Find(thisRow)
this one output a number in third column.
The next step is to put a function behind the checkbox:
enjoy, Cheers, Christiaan
Yes, the problem is that you’re probably comparing him to himself.
currentValue.name == name (currentValue) but need name thisrow.
More details :
thisTable.filter(currentValue.Name == thisRow.Name ).find(thisRow).count() > 1
or like @Christiaan_Huizer proposal, which works very well
@Christiaan_Huizer @Math_24 solved. Thanks alot guys.
