Typing into text fields in the Coda app on Android (including latest OS) is a very frustrating experience. The format bar covers the first line. The cursor constantly moves around. Often when I select text it immediately becomes unselected for no apparent reason. If you could just fix that, it’d make a big difference.
Hello @David_Knell
Thank you so much for bringing this to our attention! I went ahead and logged this bug with our engineering team for investigation.
Once we find a resolution we’ll let you know.
Jesus.
Hey @Jesus_Guzman ,
Great you have brought this to the attention of the engineering team. There is another really nasty entry issue: try entering your birthdate in a date field in android. Unless you are really persistent, it is just about impossible, for sure if you are of my generation ![]()
Android has (like IOS) so many native solutions for this, I am sure Coda can fix this,
Greetings, Joost
This issue needs a bump. These issues are still very present and very frustrating.
