The pop-out formula editor is not rendering correctly. This problem is recurring across separate Chrome environments so it’s not an issue of resources not fully loading.
As you can see below, the top portion of the editor doesn’t display enough space. This issue began appearing for me some time in the last ~10-20 minutes. Things were working fine prior to that.
Hi Christian, thanks for reaching out!
We have a fix ready for this issue, it should go live tomorrow morning.
I will make sure to let you know once the fix goes live.
Cheers!
Jesus.
Any updates? Morning has come and gone and this is really slowing me down today! Thanks.
Hello Christian, the fix is live. Sorry for the inconvenience.
Thanks.
Jesus.
Thanks! For anyone still stuck, a hard refresh does the trick.
